A/C Info Needed
A/C Info Needed
I just ordered NESS SS STAGE II SUCKER KIT part #402-429. I have Vance & Hines 2 into 1 slip-on on the bike. Question is when I change the stock A/C will I need to have a Dyno done or just add a powervision P2 tuner? What effects will I see just changing the A/C by its self? Thanks ahead of time.
Tim
Read more: http://switchbackowners.proboards.co...#ixzz2Uh74vMx0
Tim
Running the AN A/C and the V&H pipes, you will get a small benefit in power, and some extra heat with no tuner.
The FL-ViED-10's or the FL-XiED-10's will give you a nice bump in power and smoothness in acceleration, they will also keep the heat down as well and get you running a richer, which is better since they are so lean from the factory.
Click HERE for more info on them.
Here's a chart to give you an idea of the benefit.
If you want a full tuner, I don't think you can do better than the Power Vision from fuel moto. It has auto-tune basic as part of the package, and will give you a better tune than the majority of tuning done with Dyno's.
__________________
TRICK!?!? From Harley- See Here
OR
TREAT from DK Custom Products ~ 10% Flash Savings on All Air Cleaners, use Code: Clean10
DKCustomProducts.com
OR
You know the AN stage 2 A/C on your bike will do nothing extra over the stage 1 apart from look big, right?
Depends what you mean by "need". Will it break the bike? No. Will it run hot and you won't get the best power? Yes.
If you add a tuner like the PV, SEPST or TTS and use a canned map you will get 95% of the best tune without paying for dyno time. If you want to sweat the small stuff then go the extra mile and get it dyno tuned too.
Kicks
04-27-2014 09:41 PM
