With the new T-bars, I couldn't see my PV the way it was mounted before. I cut a piece of PVC, epoxied some nuts inside, cut a piece of 3/16 threaded stock to fit, rattle canned everything satin black, and mounted it up. Now I can see the PV through the risers.
So you did this on a wide glide? what yr and what did you do to make fairing fit perfect? fabricate any new brackets or use all of H-D parts recommended?
No, it's a Street Bob. List of parts and numbers is further up.
confused on the bung king spacer what do you mean flip it 180 ? can u take a pic of what u mean
The BK spacer doesn't get flipped, it's just a cylinder. The headlight block is what gets flipped/rotated 180 from it's normal position. This puts the headlight further forward to mate flush with the rubber ring in the fairing.
Can you tell me how tall and what diameter the round spacer is ? Does it go under the headlight mounting block. I bought i used fairing off ebay and it has everything except the spacer.
Not without taking it off, but you can get them at Ace Hardware in the fastener section. I think the BK spacer is 1" tall with a 3/8" ID. I wanted my headlight a little higher, so I bought a 1/4" spacer there and put it under the BK spacer.
If they don't have a 1" spacer, just get a couple 1/2" or whatever. You can stack them.
