Crossbones Air Cleaner Cover?
Good call. Just looked it up, this is the one they have (also in chrome):
http://www.dkcustomproducts.com/Blac...-AC-CVR-BB.htm
This is one of the reason I went with the BS2, the filter is smaller on the back plate side and gets larger as it is goes out, just squeezes into the cover.
http://shop.arlenness.com/p-3720-200...-stage-ii.aspx
Check out the Air Cleaner covers that we have at this LINK If you like the Bobber style covers, we have 3 to choose from.
__________________
www.DKCustom.com
662-252-8828 Voice
662-420-4891 Text & Voice
Support@DKCustomProducts.com
www.DKCustom.com
662-252-8828 Voice
this is a crossbones cover modified , if i recall it is too deep for the SE round backing plate and some needed to be trimemd off, however, i not only trimmed some off the back but also notched it to give it a open look as well ...then had it PC and ordered the SE center piece [IMG][/IMG][IMG][/IMG]
OK, so I received my DK Customs bobber cover a while ago and finally installed it last night. Turns out the top edge connects with the SE backplate causing a space at the center bolt mount.
What's the recommendation here...1 or 2 washers between the filter and cover as a spacer, or a deeper filter cone? Stupid question, but please humor me...
