Xenon bulb in headlamp
RE: Xenon bulb in headlamp
ORIGINAL: Biker Bob
Hey Phreak, how much brighter would you say the new bulb is? Thanks, BB
The white light adds to the appearance of being brighter as well.
I had an extra GM 9006 55W Bulb lying around after I put the Blue Lights in my 2K Z/28.[/align] So I drilled a large hole about one inch under the stock HD (Blue) Bulb made it a snug, push-infit - after I filed the plastic ring that's in front of the O-Ring. I then, after cleaning out all the plastic / dust out of the lenswired it into the high beam so both bulbs light. It angles up towards the stock bulb and is about a 1/2 inch from it - tip to tip.[/align] It is BRIGHT... WAY Bright.[/align] I was going to replace the stock headlight housing anyway so I figured if I 'effed it up - no big deal. I added a bead of silicone around the bulb as insurance to keep it in place. Works great - Cheap.[/align] Now I want to replace it with a Blue Bulb - and keep the stock light...[/align]
I finished installing my Silverstar and it is whiter and brighter and only took 15 minutes tops. My estimate is 25% to 50% brighter and a good buy at 20 bucks. The hardest part was finding the little nut that shot across the garage floor when I loosened it too much. I also installed chrome head bolt covers and at 50 bucks, not such a good deal but very cool looking! Those took me 30 minutes to install. Thanks for all the good advice. BB
