Thunderheader Paint/Ceramic Question
So it appears, having upgraded the engine to 107", that my wrapped-up Thunderheader won't hold on to that BBQ paint anymore. It keeps flaking off in huge chunks after about 8 miles fom the driveway. My next solution will be to strip the thing down with Aircraft Stripper and try some engine paint instead, but I'm not optimistic. My question-would it be possible (or advisable) to just ceramic coat the muffler portion (it is all one welded piece-headers and muffler) and still wrap the headers? Or would it be wise to Ceramic the whole thing and then just wrap over it?
Did you "cure" the paint as per the instructions? Also I've found that Rustoleum holds up better than VHT you might want to give that a try. I had mine sandblasted down to bare metal then painted it with VHT which rusted almost immediately so I sanded it lightly and resprayed it with Rustoleum which seemed to hold up allot better.
I used flat BBQ paint (Rustoleum High Heat) on it the first time, which held up. But after building the motor I repainted it with the gloss BBQ paint (Rustoleum Ultra High Heat). I did also used high heat primer under it this time, which could be the reason for the chipping. Probably should try a higher quality paint.
