buy extra for bob
Old 02-16-2007, 06:27 PM
cafish's Avatar
cafish
cafish is offline
Default buy extra for bob
wandering if anyone had part no. for passanger foot pegs on 06 street bob also brackets hope they come in black to match front also going to put hd pillow seat on and need part no. for back rest supports and if seat comes with all i'll need to install =if anyone has done any of this and has time to post info on numbers and any info on installing thanks[&:][8D]
Old 02-16-2007, 06:31 PM
phreak's Avatar
phreak
phreak is offline
Default RE: buy extra for bob
The HD Parts & Accessories catalog is the best place to phind the part numbers.
BUT, I can tell you that the passenger phootpeg supports that come in that kit are chrome. [:'(] Somewhere I have the part number phor the wrinkle black passenger phootpeg supports.
Old 02-16-2007, 06:51 PM
phreak's Avatar
phreak
phreak is offline
Part list phor wrinkle black passenger phootpeg setup
4059 (x2)
4180 (x2)
7778 (x2)
50912-72 (x2)
33048-72 (x2)
49230-06
49224-06
That should get you all the parts you need to build your own passenger pegs in wrinkle black.
Old 02-16-2007, 07:06 PM
cafish's Avatar
cafish
cafish is offline
thanks man don't have the catalog and ever time i go to the hd store its like burger king trying to explain to whos behind the counter there either on the phone or trying to nail some gal in there mind but anyway thanks for the numbers
Old 02-16-2007, 08:03 PM
dubblist's Avatar
dubblist
dubblist is offline
I ordered mine a month ago from my dealer and still nothing...boooooo so I went and upgraded the pegs in the mean time
Old 02-16-2007, 08:05 PM
rob_will's Avatar
rob_will
rob_will is offline
You may wanna check ebay. That is where I got mine. Local dealer wanted 45.00 each plus the cost of the mounting hardware and the OEM pegs. The whole setup would've been well over 100.00 for the whole thing, and I just wanted stock stuff.
I found the mounts on ebay for 31.00 for the set. I then bought the hardware from the stealer and some other pegs. All and all I spent around 50.00 for the entire setup.
Good Luck
Old 02-16-2007, 11:32 PM
Original Junior's Avatar
Original Junior
Original Junior is offline
Location: The birthplace of our nation- Philadelphia proud!
ORIGINAL: phreak
4059 (x2)
4180 (x2)
7778 (x2)
50912-72 (x2)
33048-72 (x2)
49230-06
49224-06
For the set in wrinkle black
Passenger Footpeg Mounting Kit
Required for use with two-up seats on '06-later FXD and FXDB models.
50210-06
Fits '06-later FXD and FXDB models.
MSRP US $69.95
Old 02-16-2007, 11:40 PM
Original Junior
ORIGINAL: Original Junior
ORIGINAL: phreak
4059 (x2) SCREW SELF TAPPING
4180 (x2) BUTTON HD TORX SCREW .375
7778 (x2) NUT
50912-72 (x2) SPRING WASHER
33048-72 (x2) FOOTREST AXLE ASSY.
49230-06
49224-06
50210-06
MSRP US $69.95
Forgot to update what each part is. I could not find 49224-06 but I assume it's the right side mount. Better option is to go with the set, 50210-06. It's cheaper buying it that way.
Old 02-16-2007, 11:42 PM
Original Junior
By the way, what is 33048-72 (x2) FOOTREST AXLE ASSY.? Are these the rubber foot pegs that come standard on the bike if equiped? Just curious because I'm not going with them if they are. Thanks.
Old 02-16-2007, 11:46 PM
phreak's Avatar
phreak
phreak is offline
Yeah, if I remember rightly, they are the pegs.
Curioius that they want 70 bux phor the "kit" when I priced out the parts individually, it came to 62 bux and change.
Quick Reply: buy extra for bob
