True track didnt fix wobble
So I thought the true track would fix the wobble at high speed and it seems it did but i have also experienced a slight wobble when powering out of right hand sweepers. Thought that would have been fixed but It's still there. Im convinced I just need to tweek alignment or pressure in the tires but since I was bored and hit up some you tube videos I got to thinking. Has Harley ever acknowledged the issue of the wobble on the rubber mounted bikes? I couldnt find anything on their site but there are tons of videos and articles on the net attesting to the existence of wobble. I would assume the MoCo would have released something on it. If anyone has info on it I'd like to see it.
Next, and this came from Don at TT, check to see if the front tire was mounted incorrectly. To do this look at the ridge at the edge of the rim. The small ridge should be an even distance from the rim edge all around. If not the bead is set incorrectly and the tire is essentually out of round (my problem and a common HD problem). Unfortunately if the front tire has more the 1000 miles on it then it will have already begun to cup or scallop which will cause wobble problems to become worse and worse as time goes on. The only cure is replacing this front tire.
Next is alignment which apparently is a common problem where the rear is not aligned correctly causing precisely your symptom (this will also cause the front tire to cup/scallop).
Also have the rear swingarm bushings checked.
Bob
The owner of this Dyna spent some time looking for the source of his "wobble" before he found this..You are going to hear a bunch of things to check I'm sure but hey,check em all ya know.Other things I've read are things like setting your rear shocks to the firmest setting and different fork oil in the front.Hope you find it.
What is your definition of "High speed" that you are experiencing this wobble? 70? 80? 100?
Chances are is you will not get an answer from the MOCO, because they will state at the posted speed limit they do not experience this wobble. I have had my WG wobble at high speed, excess of 80+ and backed off the throttle. But haven't experienced it at 70.
