??? on installing forwards on 06 Superglide
Old 02-16-2007 | 01:27 PM
Trotter's Avatar
Trotter
Default RE: ??? on installing forwards on 06 Superglide
There's no way mine would come out with out removeing the inner primmary cover, the shaft that has to come out is 5 1/2" long. There's not enough room to pull it out the back, with out pulling the primary outward to gain enough room between the primary and lower Case. I had to use a brass freez plug to seal theshaft hole on the Inner Cover so oil wouldnt leak out the back side. Trotter
[IMG]local://upfiles/24219/18B53AD0E4C14DCFA91EE258A5D28C2D.jpg[/IMG]
Old 02-16-2007 | 01:38 PM
Trotter's Avatar
Trotter
Reach around to the back side and feel if it's not still there ?
Old 02-16-2007 | 01:54 PM
HOGRIDA_06's Avatar
HOGRIDA_06
It can be done without removing the inner primary, but if your going to the dealer in a few weeks anyway, I'd probably just wait. Here's a link to some pics. of my set up.
https://www.hdforums.com/m_576946/tm.htm
Old 02-16-2007 | 08:46 PM
soup48's Avatar
soup48
I took the forwards off of my '04 FXD and installed them on my '06 FXDCI. The only thing that I had to buy was the shift rod, because it is longer. The primary cover is made a little different. It looks great.
Andrew17019
07-08-2013 03:03 PM
QC-RAIDERS-91
03-01-2013 06:14 AM
07FLHP
08-09-2010 05:33 PM
NEW2BAG
12-13-2008 08:36 PM
Roadrider18
01-10-2007 04:54 PM
Quick Reply: ??? on installing forwards on 06 Superglide
