3rd inner primary leak !!!!
Well,
once again , another leak !!! just had it fixed saturday, and again for the 3rd time "it leaks"... took a ride to day, down the interstate about 70 for about 15 miles and about 60 for another 20 miles ... it's leaking right below the front sprocket.. i wiped it all clean and rode and then took a mirror and a light like someone on here told me and there it was "the dreaded leak".. man , i'm so tired of takeing it to the shop about 50 miles away.. so now i have to take off work to get it there... any ideas what i should tell them ?
RIDE ON
KMAN42OO
RIDE ON
KMAN42OO
RE: 3rd inner primary leak !!!!
Hello everyone, new member here. On the primary, as of 4/4/04 harley sent a memo to their dealars. Inter primary and jack shaft seals are to be replaced with beter gaskets. why? Because the old ones leaked. They also told their dealers to use up all the old ones befor using the new improved ones. I've seen the new ones and they are far more better then the old ones. Also, you say this leak is coming from the front pully? Do you mean the the main transmision shaft? If so, that is the interprimary seal leaking. Put dye in your transmission to see if it is coming from the shifter shaft, or use red line transmission fluid. I have more but American Thunder is coming on, have to go. Go luck. By
