will these fit 06 street bob
Old 03-23-2013 | 11:16 PM
civilbob's Avatar
civilbob
Default will these fit 06 street bob
http://www.cruisercustomizing.com/dr...t/DS-2020-0347
thanks. Just want a definite answer before i order.
Old 03-24-2013 | 12:45 AM
Jbco2's Avatar
Jbco2
your SB has 49mm, yes they should fit.
Joe
Old 03-24-2013 | 01:18 AM
Gommee's Avatar
Gommee
Devil's Advocate
If you are going this direction. Just order a second signal mount that is used on the left signal and and use existing pinch bolts.
Old 03-24-2013 | 03:57 AM
n0code's Avatar
n0code
Don't order those, they dont fit right. I've ordered some in the past and now they're paper weights.
Old 03-24-2013 | 08:48 AM
SuperFastGlide's Avatar
SuperFastGlide
they will work on 06- 07 not on 08s and up
Old 03-24-2013 | 09:05 AM
blueangel73's Avatar
blueangel73
"Fits: '87 to '00 FXR, '91 to '05 Dyna Glide and '87 to '07 XL models fitted w/ 39mm forks and turn signals mounted on the triple trees. '06 to '07 Dyna Glide w/ 49mm forks and front signals mounted on the triple trees "
Old 03-24-2013 | 10:14 AM
thedonthere's Avatar
thedonthere
I have a set and they work fine
Old 03-24-2013 | 01:48 PM
bobnehoc's Avatar
bobnehoc
Mine fit fine on my 07 LR. Paid about the same price and I got them Dennis Kirk. The only thing I did not like was the chrome is peeling on them and they are about a year and half old.
Old 03-25-2013 | 03:21 AM
Joboo1966's Avatar
Joboo1966
The link you enclosed in your post has a check fitment link which says yes they will fit your bike. Assuming you have stock front end and parts associated wit the stock front end and not some weird hybrid you should be ok. It's Drag Specialties so it should be pretty good quality.
Timmowle
Exhaust System Topics
07-09-2018 02:04 AM
J_drizzle
05-31-2015 02:48 PM
maximuswaximus
11-30-2013 10:11 PM
huskytamer
10-30-2011 08:15 AM
jaysbobber
09-09-2010 08:25 PM
Quick Reply: will these fit 06 street bob
