Screamin' Eagle Pro II slip ons?
How do Screamin' Eagle Pro II slip ons sound on a Dyna? I understand that Harley doesn't sell them anymore, why? DO I need to any modifications to the carb? I have seen alot of talk about the Rush slipons. Are they about the best as far as sound and performance? I can get the S. E. for under $100.
Thanks,
Larry
Thanks,
Larry
RE: Screamin' Eagle Pro II slip ons?
ORIGINAL: bronk
I like my SE2s! Not too loud,but still has the growl.They sound really good at idle and start up, and tend to level out at cruising speed.I wear earplugs now with them as well.
I like the sound of my SE2s and Big City Thunder baffles. The deep, throaty sound rocks and the power is noticeable. If you like the appearance of a stock exhaust, they're a good, inexpensive combo. I like the look of the V&H Side Shots. One of these days...
As for your other question, with slip ons alone, you shouldn't need any carb jetting or EFI adjustment. If you open up the A/C, you'll be really lean.
Good luck!
Good luck!
I too have an 06 Wide Glide with Se11's, Stage 1AC, Stage 1 Race Download and Big City Thunder baffles. The sound with the new baffles is a bit louder without being obnoxious, but a nice deeper tone. I haven't noticed any loss of power throughout the RPM range either. They took only 20 minutes to install, and I believe a great addition for $130 bucks. If anyone knows whether the Race download is sufficient or whether a SERT or PC!!! might be necessary down the road let me know. Plugs seem good so far, but haven't riddent with them in the heat yet. Let me know your thoughts, only as to "necessity". Shovelhead Bod usually has good insight into these things.
