Wheel bearing replacement
Old 02-19-2013 | 10:48 AM
Wakko47's Avatar
Wakko47
Default Wheel bearing replacement
What part numbers do I need for the wheel bearings on my '96? Preferred place to get 'em? Florida Bearings is near me, I can bring the old ones over to match them up unless there's a hazard to that.
Old 02-19-2013 | 11:04 AM
FXD2003Rider's Avatar
FXD2003Rider
Administrator Emeritus
Have a look over here, Wakko:
Front: 9052
http://www.shopronniesharleydavidson...-40801-HD96083
Rear: 9052
http://www.shopronniesharleydavidson...-40903-HD96099
Old 02-19-2013 | 11:14 AM
Wakko47's Avatar
Wakko47
Thanks, FXD. I read quite a few threads on the subject and some folks recommended aftermarket versus HD bearings. Any thoughts on that?
ETA: I looked at the 9052 and see that it's not a complete sealed unit like I thought, just a place in bearing with pressed in races. Looks like the basic GM front wheel bearing on the old RWD models actually.
Old 02-19-2013 | 12:27 PM
FXD2003Rider
I'm sorry to say I cannot answer that question.
If you take a look at this link you'll find the bearing's dimensions. This info probably could help you to find sealed bearings if that's what you prefer.
Looking at the parts diagrams I posted previously, I also see an oil seal used (p/n 47519-83A) with the Timkens
If this is the first time after all those years you have to change the bearings I'd buy the oem ones....
Old 02-19-2013 | 01:00 PM
Wakko47's Avatar
Wakko47
Thanks for that link...it helps.
I've only had the bike for a year, and there's nothing apparently wrong with the bearings, but if I'm gonna pull the wheel I figured I'd swap them out while I was there since they're not much money. I will definitely swap the seal though, I get a small amount of grease fling.
I'm still shocked that it's the open type bearing on this thing...my old Sporty had sealed IIRC.
ETA: Now that I think about it, I assumed that the sporty was sealed since it stayed together even while putting on a new tire, but now I think it just held with grease really well. I'm a moron.
Old 02-19-2013 | 04:17 PM
Gommee's Avatar
Gommee
Devil's Advocate
HD does not make the bearings, a good bearing manufacturer is always the best bet.
My 07 has sealed bearings front and rear.
My rear bearings came from a farm supply store made by a well known mfg. Probably outlast any HD installed bearing. Just match up the numbers stamped on the bearings and you will be fine.
Old 02-21-2013 | 10:18 AM
Mike's Bike 95 FLHTP's Avatar
4th Gear
Wakko47, I recently replaced wheel bearings, races & seals on my brothers '95 FLHTP w/Timkin LM11949 Taper Bearing Cone $7.28 ea., Timkin LM11910 Cup (Race) $3.92 ea. and D5118 Seal $2.00 ea., these are a very common bearing set, check out your local industrial supply houses (Bearing,Belt & Chain) or trailer repair shop. I use a multi purpose high temp bearing grease, and check end play after assembly. this link may help: xlforum.net/vportal/forums/showthread.php?threadid=1607256. And all parts used in this assembly are proudly made in the U.S.A.
You can also go to Timkin's home page for cross refrence to OEM part no.
Keep yer knees in the breeze.
Old 02-21-2013 | 10:27 AM
razors edge's Avatar
razors edge
Im like Mike, I go to a bearing store for bearings. Cheaper and better bearings.
Old 02-21-2013 | 12:23 PM
Wakko47's Avatar
Wakko47
Thanks for the advice guys. I may tackle this over teh weekend. Welcome to the board, Mike...introduce yourself over in the Evo forum too.
skydude426
01-11-2016 09:33 PM
Imold
General Topics/Tech Tips
01-08-2016 08:56 PM
bobbleheadray
Wheels/Tires
10-30-2012 09:13 AM
mrreb57
Shovelhead
05-30-2010 11:56 PM
rider
09-30-2007 06:26 PM
