Winter work on the Fat Bob
Previously modified with:
V&H Big Radius 2-into-1 Black Exhaust
SE Heavy Breather w/ Cut Back Cover
SE Pro Super Tuner
HD Cut Back Fat Bob Wheels
HD Black Brake Disks
HD Cut Back Belt Sprocket
HD Black Denim Horn Cover
HD Black "103" Derby Cover
HD Black Belt Guard
HD Black Fender Strut Covers w/ Detachable Hardware
HD Detachable Leather Dyna Bags
Work that is currently underway:
10" Black West Coast T-Bars
HD Black Get-A-Grips
HD Edge Cut Hand Controls
Ricor Intiminators
HD Diamond Black Cables and Brake Lines
Superbrace Fork brace
HD Tribar Tail Light
Ricor Sport-tuned Shocks (+1/2" over stock)
True Track
HD Combination Analog Speedo/Analog Tach
HD Flush Mount Fuel Cap & Guage
Indy Built Stage 4 Kit (target output 110 tq/100+ hp):
Crane 296 Cam
58 MM EFI Manifold
58 MM Throttle Body
10 Liter BK Big Valve Heads
Roller Rocker Arm Upgrade
Port and polish heads
True, balance, & weld crankpin
HD OEM Mid Position Peg Mounts
HD 4" Mini Footboards on frwd controls and mid mount peg position
HD LED Headlight and headlight housing
Rifle Roadster Quarter Fairing w/ 15' windshield
HD LED Rear Turn Signals - Smoked lenses
HD Mirrors w/ LED turn sigs (flipped - eliminate OEM Turn Signals)
HD Edge Cut Brake Arm and Pedal
HD Edge Cut Shifter Arm, Peg, & Shifter Linkage
Big City Thunder Monster Baffle Original Monster Baffle
Current Progress:
SE Pro Super Tuner
HD Black Belt Guard
Ricor Intiminators
True Track
Crane 296 Cam
58 MM EFI Manifold
58 MM Throttle Body
Current Progress:
Thanks everybody, will post pictures of the finished product.
@ JRK5892 - I've already horse traded most of the OEM parts for various other goods, services, and discounts.
@ Puffdaddy - I wish I'd have seen that taillight previously, I had looked at the Kury panacea to eliminate rear turns but didn't care for the OEM shape of the light... I will see if I can swap the HD for the cycle visions taillight before we close out the RO.
@ alansummrs - I am just replacing the front turns with the turn signal mirrors.
I actually went back to the Fat Bob rear fender after installing 13" shocks. It looked like I had a dirt bike with the wide glide fender so high in the air above the tire. That and I wanted to install bags and go back to having the license plate on the fender.
