Air Shock Oil Question
I got a pair of Street Glide shocks for my Dyna, which were shipped with the air lines installed.
I removed an air line from one of the shocks and oil leaked out of the quick connector.
I think the factory service manual for a 2011 Street Glide is full of **** when it instructs the replacement of the shocks when this happens.
My question is to those who have OEM air shocks:
What type of oil and how much of it goes into the 11" Street Glide shocks?
They got me too when I was swapping to Schrader valves. Do a search search. I found something that talked about weighing them and making them match. It looked like I lost a lot but it was barely any and they weighed about the same. Difference was like .02 ounces. I've put about 3k miles on them and they ride great. I miss the lowered look, but the 12" street glide shocks save my back and are a lot more fun in the twisties. Oh and I believe it's just regular shock oil. I might swap out to some AMSOIL Shock therapy one day. But right now I like the way it rides.
I thought I kept the thread I mentioned above, but I can't find it. I read that some mix 5 and 10 wt 50/50 to give it a 7wt ish blend. I thought about doing this myself. Stock I believe is 5 wt and as cush as the 5 wt is I wouldn't mind a little stiffness with less air. Someone said 10wt was just a little to stiff. If I come across that thread again I'll post it up. Might have been several thread I read, who knows. I can't remember 6 months back....lol!!
i used 11oz of 10wt bel ray shock oil in each when i refilled, i drained them by hanging upside at an angle down for a few days and measured 11oz out of one and about 10.4oz out of the other..
when i received them there was some oil in the shipping box so i gathered that was where the other.6 went
Here you go. I also used 10 oz of 7W BelRay fork oil on my 13"s.
https://www.hdforums.com/forum/touri...ur-shocks.html
I love the ride. I have the 2011 12" street glide shocks with the stock oil in it. I run 35psi and it's like riding a lazy boy. I bump up the pressure to 40psi when I know I'm going to play in some hard twisties, but at 35 it does just fine. Before I went to this I had 11" progressive 412s and of course stock before that. The 12" lowered SG shocks are the same length as your stock SB shocks.
