Need Help...Removing Stripped Hex Bolt
Old 01-01-2013, 09:31 AM
OldMike's Avatar
OldMike
OldMike is offline
Received 1,927 Likes on 1,260 Posts
Originally Posted by chuck3049
The way I have do this is to take a sharp chisel and a hammer, do as stated above use a punce and tap a couple times in the middle of the bolt to loosen then use the chisel to back it out. take your time with care and it will come out.
This.
A cold chisel, correct size and length to fit into the space. Cut a groove into the side of the bolt head hitting it straight on then use that groove to drive the bolt (controlled hard hits) counter clockwise to loosen, then pliers or the Torx bit to finish. This is a second to last resort before chopping the bolt up with a Dremel.
scooper321
Wheels/Tires
24
02-11-2018 09:31 AM
Van Buren
04-21-2013 08:15 PM
Big Sled
04-25-2008 07:19 PM
Lone Watie
01-16-2008 12:17 PM
Tin Man 1
10-20-2007 06:05 PM
Quick Reply: Need Help...Removing Stripped Hex Bolt
