WideGlide front Wheel
Gaday folks...I have a 2010 WideGlide and wanting to swap out the front wheel to something wider...I don't mind 21" or 19" and don't want anything real flash(the same as stock only wider is good)but want a straight bolt in option...Any one have any ideas other than buying a wider rime and lacing to my existing hub??? Any other model's wheels fit??
Cheers...Sparra
Cheers...Sparra
You really have a very wide array of choices...depending on how much effort you want to put in it.
You can buy spacers for the rotor to allow non Wide Glide wheels to be used on a Wide Glide front end.
Short of that, you need to find a wheel for the WG front end. Tons to choose from.
From HD's web site, here are the interchangeable models
21" Front
Fits '00-later FXS, FXST, FXSTD (except FXSTDSE), FXSTB, FXSTC, '00-later FXDWG and '08 FXDSE2 models.
Hope this helps
21" Front
Hope this helps
