My new Fat 50's!!
Old 01-12-2013 | 09:58 PM
trainedkilla's Avatar
trainedkilla
Originally Posted by Mascman
Sounds like that is exactly what happened. Can't really blame the dealer onthat one.
I never blamed the dealer. I will say that it is an R&D defect to attach a piece so heavy on a bike with alot of vibration with 3M tape only. The area gets hot also.
I made it worse by powder coating and not replacing the tape. The shop that had the bike in their care at the time that it came off is going to replace the piece. I offered to pay half but they said they would cover it. I will have to paint the lettering again though.
  #72
Old 01-13-2013 | 08:34 AM
Mascman's Avatar
Mascman
I wasn't saying that you blamed the dealer per se...just meant that it wasn't their fault.
That piece will stay just fine with a good tape on it. I removed mine and had Joe the Powderpro strip the paint from my battery cover, then he polished it to look like chrome. I used 3M tape on the band probably over 5 years ago or more and it is still there.
  #73
Old 01-13-2013 | 08:39 AM
trainedkilla
I have done a little research on this forum and there seems to be a common problem with that band falling off. I am just going to drill a small hole and bolt it down...along with the tape to prevent the rattle.
  #74
Old 01-13-2013 | 09:30 AM
Mascman's Avatar
Mascman
Just checked mine to see if I should be concerned cause I didn't know anyone was having an issue. It's holding tight.
I wonder if the issue is with the stock tape? Like I said, I removed mine before...and if I remember right, I just got under the edge and was able to pull it off...no heat or anything to help.
Since I reattached it with quality 3M stuff, I probably did myself a favor.
Might be worth not even using the stock tape and just getting some 3M trim tape on your new one?
jokr
12-20-2008 12:02 PM
BUSCHA
12-16-2008 03:41 PM
20FXST06
05-11-2008 09:53 AM
moggsy
08-02-2007 08:45 AM
Badbagger
07-26-2007 03:32 PM
Quick Reply: My new Fat 50's!!
