Any extensions/fwd controls available for the Switchback?
Hello,
I'm 6'2", and I'm expecting the riding position on the Switchback to be a bit cramped for me. Are extensions/forward controls available for the Switchback? If not, is there a workable solution to move the controls forward for a little more room?
I've seen a few post, which are a bit dated, that did not have a solution to this...
I'm aware of the tallboy seat, but hoping there are actual extensions/fwd controls available as well.
THANKS!!
THANKS!!
Hello,
THANKS!!
THANKS!!
http://roadrails.readingdesigns.com/
Very pricey but they are awesome. I visited the designer personally and it is one fantastic invention. In the $1500-2k range.
If you find something else, I'd be very interested too. Been looking for something for over a year.
Half of my boot sticks out the front. This is a friend's bike and he has the crashbar...maybe that's the only way to go as afmm3 said:
A set of forwards off any FXDWG or Fatbob should fit straight on. Then it's a matter of getting an extension plate kit for those which includes a longer brake and gear shift linkage.
The actual mounting part of the floorboard should be the same on all models, only the bracket to the frame will be different. If you can get a kit that moves the board forward or out from another model it may be interchangeable. Its just a matter of looking around.
