Rifle fairing on wide glide
Old 11-21-2012, 07:37 PM
G-Lock's Avatar
G-Lock
G-Lock is offline
Default Rifle fairing on wide glide
My fairing finally arrived. I'm working on the install. What are some thoughts about the way I'm setting up the support struts.
Old 11-21-2012, 07:39 PM
G-Lock's Avatar
G-Lock
G-Lock is offline
The struts on the fairing...are they to vertical?
Old 11-21-2012, 07:59 PM
Psi23's Avatar
Psi23
Psi23 is offline
looks good to me!
Old 11-21-2012, 08:03 PM
G-Lock's Avatar
G-Lock
G-Lock is offline
The instructions also say to drill a hole in the bottom of the fairing to run the bolt through to the under headlight bracket. I'm thinking of finding a specialty type fastener and using gorilla glue to adhere it rather than drilling a hole. Any thoughts on this?
Old 11-21-2012, 09:39 PM
n0code's Avatar
n0code
n0code is offline
Can't wait to see it mounted up man! I just ordered mine so I'll be looking forward to your tips.
What was the turn around time for you?
Old 11-21-2012, 09:45 PM
Psi23's Avatar
Psi23
Psi23 is offline
If I'm not mistaken, maybe 07bobber can chime in, I think he just tightened it up with only using the quick release on top clamps. Also heard of others justing turn signal clamps to mount bottom.
Old 11-21-2012, 11:48 PM
oldlefty's Avatar
oldlefty
oldlefty is offline
just ordered one of these for my SB. i asked rifle if they had mounts for 49mm forks but they didn't say in the email. ordered anyhow. we'll see when it shows up unless you guys are savvy to this info.
Old 11-22-2012, 02:13 AM
G-Lock's Avatar
G-Lock
G-Lock is offline
I think I took delivery of my fairing about six weeks after I ordered it. Rifle doesnt bill you for the item until it ships. The fairing looks great and they did a great job packaging the unit. So far I have used two HD quick release mounts off of a windshield I got with the bike. The Rifle instructions are generic and I already had to make a run to Lowe's for some parts. To move the headlight I used two of the tabs they provided and I bought some 3/8 aluminum tube stock to act as a spacer between the mounting tabs of the stock headlight bracket. I will take some more pics and add to the thread after Thanksgiving.
Old 11-22-2012, 02:54 AM
kateean2's Avatar
kateean2
kateean2 is offline
Old 11-22-2012, 04:36 AM
G-Lock's Avatar
G-Lock
G-Lock is offline
Yeah.... I dont think I need to drill a hole in my fairing to create a strong mount under the headlight.
Quick Reply: Rifle fairing on wide glide
