Rifle fairing on wide glide
#31
#33
there are some 3M products that can be used. 3M panel bond is the strongest and you can sand it after 24 hours if needed. you may need to use an adhesion promoter before applying. also hit the spot with 80 grit sand paper so it has something to bite onto.
it all depends on the surface of the fairing ie if it is smooth or strand type fibre glass.
you should go to an autobody and paint supply shop. they will have the products to do it right and hopefully they will have the smarts to give you the right stuff.
important to know what your fairing is made out of too. READ the bottle's do's and don'ts before use so not to melt your fairing but i have been told that panel bond it the best. my good friend owns a high end body shop and they use it all the time.
hope that helps.
hope that helps.
