Brighter Headlight?
RE: Brighter Headlight?
Seen this in the latest Easyriders rag, looks like what I am gonna go with.
http://harleyzone.tenmagazines.com/t...124&sid=20
from the webpage:
from the webpage:
One of the newest products Delta Tech Ind. offers is the new low-amp draw motorcycle H.I.D. headlight series. They offer a range of different sizes and configurations for different motorcycle headlight styles including Harley-Davidson and custom choppers using standard 7-inch or 5-3/4-inch round headlamps. Both the FATTY 700 7' Low-amp Draw Motorcycle H.I.D. Headlight and the SLIM 500 5 3/4' Low-Amp Draw Motorcycle H.I.D. Headlight come with a 21 watt compact ballast/igniter which draws only 1.75 amps per light and will not drain your battery. They are a direct replacement for your stock headlights. At 6,000K rating, these systems will exceed daylight brightness by 10 percent!
And what about these:
http://www.xtralights.com/index.asp?...amp;ProdID=439
http://www.kuryakyn.com/products.asp...ey&ci=3728
Check out www.store.adjureinc.com Excellante product.
You might have trouble linking to this so Google "Adjureinc" and this should land you the site.
JohnnyRebKY
05-04-2015 09:34 PM
JGmx327
03-22-2015 10:55 PM
