Trouble Starting
Hey guys, so a month or so ago I tried to start my bike and all I heard was the starter click. So I decided that I would throw a battery tender on it. I had the tender on it since saturday, and the light was green which the instructions say is just the float mode or whatever you want to call it. Today I filled it with gas, put some Sta-Bil in it and went to start it. It turned over, but wouldn't catch. The light then went red on the tender, almost like the battery was dead again. Anyone know what my problem could be? I am avoiding a new battery, but thats the only thing I can think of. Thanks in advance.
Chances are it's the battery. Battery tenders are meant to trickle charge a good battery and not really meant to charge a dead one.
Take the battery out and take it to autozone or one of those places and have them check it.
You need to ride that thing....get it out of the garage
When I try to start mine without un-plugging it , will sometimes do just that and I think it's because the charger takes a read when you are asking the battery to give all she's got. Mine does that and my batt is new from this summer.Rooti is right though the best thing is to take it right off and have it checked.
Also if it is cold where you are the engine will turn over much slower this time of year.
I would do easy things first.
Get battery charge topped off again.
Dis-connect Power Commander and try to start it.
Did you wash the bike recently?
Put fresh gas in without the Sta-Bil crap.
Why was your starter clicking in the first place? My bike can sit for two months and it turns over fine. This is why even though they say your battery is OK, it might not be.
If it's turning over OK look at the PC and gas.
Take a close look at your bonding jumpers (grounds) on your battery and on the chassis (where the Batt. ground goes to the frame). Mine is on the top of the Tranny case.
The corrosion that causes a failure cann't be seen so, go after them with a small stainless wire brush.
I've had that happen before. (push start and all I got for afew seconds was " Click, click-click, click" then as the arcing at the lug heated it, it would make better contact and, allow enough current to make things go.)
Just a though....Hope it works for you.
Best wishes....Tim(HT)
