lower rear shocks
My stock shocks were 12's and I went to 11.5 in. Progressive 440's. I only ride solo so I was able to go with the standard springs. The ride was harder, as I suspected it would be, but the bad part for me was scraping stuff in what I thought were not hard corners.
Since I didn't care how the bike looked sitting still I went with longer than stock Ohlins which worked out to be the best fix for me.
Because you have a passenger keep your stock ( Height ) ones , when you lower it it's all for looks and not for comfort , BEEN THERE DONE THAT !
Anybody that "slams" their bike down with 10.5" or 11" shocks is going to give up two very important things. Those two things are called ground clearance and suspension travel.
Without adequate suspension travel, every time that you hit a nasty little bump or pothole, your shock will run out of room to absorb that hit, and bottom out. When your shock bottoms out, the force of that impact gets absorbed by the tire, the frame, your back, your ***, and your kidneys. Not a very pleasurable experience for you or your girl.
For anyone that says that their 10.5" shocks never bottom out, that's because they've probably got their sag adjusted to near zero. I'd venture to say that the ride quality of said bike would be similar to a rigid frame, or a strutted bike. A miserable experience IMHO, especially if you're riding long distance or two up.
Without adequate ground clearance, you are limiting your ability to lean the bike into a turn…sometimes drastically. Going over any kind of speed bump isn't any fun either.
You haven't really lived until you are cruising along at 80mph down the interstate and enter a nice big sweeping turn, and then hit a nice bump or road/overpass seam. When your shock bottoms out and your rear wheel impacts your fender, that strange sensation running down your leg will either be a bodily fluid or some other waste byproduct, from being bounced airborne out of your seat and almost losing control of the bike. If your old lady is still on the bike after that, she will need a change of clothes also.
Form over function, or vice versa…the choice is ultimately yours to make. Good luck.
I ride solo and have the burly 10.5. I did notice it was a little bumpier but not intolerable. After a few thousand miles I couldn't remember what it felt like before. As for turns, I ride it like a cruiser and don't bomb into turns. Havent scraped yet, except for when I went down haha
