Do I really need a choke on my 2000 FXD? I cranked the nut too hard and broke the plastic threads. Do I really need to replace the choke or can I just get rid of it? Thanks for any info.
Technically that is called an enricher, yes you need it for cold start, I have seen many ppl using thumb screw to lock the throttle during warm up, it's up to you. You can either buy the cable with the crap plastic **** or invest a metal **** so it won't break in the future.
It is an easy fix. I had to rebuild my CV and now have the enrichner attached to the top of carb - not the stock location as I relocated my ignition to the horn area.
I had never worked on a carb before and was a little intimidated on the enrichner, but took my time and it worked out fine. Made a "mountain out of mole hill."
$12 for a new cable and about 30 minutes to put it on. I would not consider taking my choke off as I like my bike to start when I need to go somewhere.
