Dealer recommends screamin eagle race tuner for stage 1 upgrade
Guys, need some advice. I currently own a 2010 fatbob an want to upgrade pipes to some Vance an Hines. I figured I'd get a v& h air intake and use the v& h fuel pak. The dealer is telling me that hey are having issues with aft market components throwing false codes and that they don't recommend the v& h fuel pak, rather I should go with Harley's se race tuner- which of course is pricey. Anyone hear of these false codes, is the dealer just trying to
Push these race tuners real
Hard?
Hard?
The fuel pak has had some issues and even so only adjust fuel. It depends on how much you are willing to spend, how well you want your bike to run, and what future engine mods you want to do.
The race tuner is a great tuner but only as good as the person who sets it up on a dyno. Most of the time that person doesn't work at the dealership.
Look into TTS also.
Look into TTS also.
I have V&H pipes, Arlen Ness Big Sucker and SE 255 cams and I am running the V&H FuelPak with no issues. Bike runs great and goes like hell with NO pinging or popping.
With that said, one day I will upgrade to a TTS or T-Maxx if any issue pop up, but until then, I ride it like I stole it!
Hard?
Hard?
I've had it on my bike since July and have had no problems, no back firing what so ever. They are only like $100 bucks compared to the other EFI tuners. I will probably upgrade someday but for now they work great. Takes less than 10 minutes to install.
Hard?
Hard?
I purchased an '03 new and went the dealer route as it was my firrst Fuel Injected bike. By '06 I was finished with the dealer and decided to try it on my own. Just purchased a new '12 in March and bypassed the dealer.
Havent heard many good things about configurability of the FuelPak compared to Power Commander. I would look for a good deal on a Power Commander V or the Power Vision. You can find PCV's for under $300 and load the program tailored for your build a lot cheaper than purchasing the HD race tuner and you don't need to take it back to the dealership. It really depends on how comfortable you are doing it yourself. If you can follow directions and download a program from the internet and hook your laptop up to your bike in the garage, you can download that program to the PCV, it really is that easy. Find a build identical or most similar, download and load. I havent heard of anyone in the last 10 years that has melted down a motor with the wrong program.
SE Pro Super Tuner and TTS Mastertune are the best options out there IMO, but also the most pricey. With either one you also need a good dyno tune, but when done the bike should be perfect. I would recommend a tuner that reprograms your ECM instead of a piggyback device. There are many options that will work, but the above two are the best if you have the $ and you decide close enough isn't good enough. Do it right the first time and you will be happy and not waste $ on other tuners first. My 2 cents.
