Best motor recipe..
Old 10-10-2012, 09:56 AM
999 Customs's Avatar
999 Customs
999 Customs is offline
Default Best motor recipe..
Picked up an 06 Super Glide with 1200 miles and the motor is BONE STOCK (TC 88).. Added a hybrid Thunderheader and an Arlen Ness Big sucker, even threw on a Fuel Pak, but she's gutless. My Evo would smash the daylights out of this 88".
So I'm looking for the best recipe for some reliable power without breaking the bank. I've already decided I'm going to pick up a set of D&D pipes, but what else ?
Will 96" cylinders bolt on, heads, maybe some injectors from a SE110 that we just took out. Just looking for some ideas.
Old 10-10-2012, 10:26 AM
07bobber's Avatar
07bobber
07bobber is offline
an evo will definitely rip up a stock twin cam no problem...just build the motor, big bore, cams, headwork, etc etc...
Old 10-10-2012, 10:30 AM
Dyna346's Avatar
Dyna346
Dyna346 is offline
Why is this? Why would harley go from a powerful platform and then change it, especially if not for the better?
Old 10-10-2012, 10:36 AM
Good_Apollo's Avatar
Good_Apollo
Good_Apollo is offline
Pretty popular and reliable build for TC88 (My brother and I will be doing this on his bike this winter):
95-97" big bore with flat top pistons (9.7:1 or so compression) - Axtell has a good price on boring your cylinders to 97" and matching pistons/gaskets
S&S 570 cams (EZ start are nice and don't require CR)
Mild headwork (Big Boyz)
A good tuner and dyno tune
This should make at or more than 100/100 and you will be happy. Your thunderheader and breather are more than adequate for the build.
In retrospect I wish I would have went with something like the build above, mine is not too much different but I have higher compression and aggressive headwork, the cams I have are to match my higher compression.
Old 10-10-2012, 10:42 AM
07bobber's Avatar
07bobber
07bobber is offline
http://en.wikipedia.org/wiki/Harley-...win_Cam_engine
Old 10-10-2012, 10:44 AM
999 Customs
Thanks for the feedback so far... If I were to do it the way I wanted, I'm looking at almost $10k. Figure I would ask around before going crazy and doing a LOT of un needed work. Thought about just dropping in the 120R, but to get that where I would want it, I'm looking at another $5k on top of the original cost of the motor. Its not the overall hp that I'm after nessisarialy, its the explosive roll on power I'm looking for. Like the 60-100mph range. Thought about gearing, but on a HD its not as simple as it is on a sport bike.
I'm gonna start looking up parts, the reason I was asking about some stock bore sizes is that I have access to MULTIPLE sets of 96" jugs and heads that are fresh and free.
Old 10-10-2012, 10:52 AM
Thunderhorse's Avatar
Thunderhorse
Thunderhorse is offline
from what i remember, the 96" got the extra cubes by a longer stroke crank. Bores are the same size.
Old 10-10-2012, 11:04 AM
johnjay's Avatar
johnjay
johnjay is offline
10 K...are you kidding...you can get a used Viper engine for that. Talk to the people at Revolution or S&S.
Old 10-10-2012, 11:24 AM
JRK5892's Avatar
JRK5892
JRK5892 is offline
my motor build is in my signature... i can pretty much play with anyting that pulls up next to me... just a blast to ride!
Old 10-10-2012, 12:11 PM
999 Customs
We are on the same Club/Outlaw page on Facebook..
Quick Reply: Best motor recipe..
