18 apes, 2011 dyna questions...
HD wanted around 100 bucks/cable, so I fired up the trust Internet, and have found them around 25-40/cable.
1. Where are some good reputable sites for purchasing.
2. What lengths should I purchase them at.
3. Anything else that I will need for the install?
4. About how many hours should my mechanic be charging me to put them on....
Speaking of, I have 1 and 1 half 18 inch apes. Will be inside wired.
2011 dyna streetbob.
Thanks for your help, and let me know if I left anything out.
Pick up a manual and do this yourself. If you can turn a wrench, there is no reason you can't do this yourself. An inexperienced person con change the bars and internally wire them over a weekend. Best way to figure your cable length is to put the bars on (temp install) and measure the distance, reinstall your current bars. Order your cables and wire extensions. While your waiting for them to come in you can still ride. you could build your our cable and brakes lines also. check out Magnum Shielding, they have both options and their cables are top notch.
