Cams or Tuner?
Your going to need a tuner that can add more than just fuel in every rpm range so fuel and timing can be adjusted in the rpm range the cam "turns on" in.
If your current set up is versatile then keep it.
If your going work SE 255s any enrichment system will work due to them not being very radical
The dobeck seems easy enough to adjust,IMO you should contact them and find out about it's capacities. I watched the tuning video on their site, that yellow pot reminds me of tuning a guitar! Adjust for smooth uniform sound and your good!
If it were that simple, why would complicated machines like dyno tables, tts, PV, or t-max even exist?
