Heated grips?
Old 09-26-2012, 10:16 AM
AllenW's Avatar
AllenW
AllenW is offline
Default Heated grips?
41 degree's this morning, not bad till I hit about 60mph and the fingers started to get numb even with gloves on.
2012 WG and need a reccomendation on heated grips, perferably not the Harley ones.
TIA
Al
Old 09-26-2012, 10:18 AM
tpcrawford's Avatar
tpcrawford
tpcrawford is offline
Heat Demons are the ticket. You can use any grip you like with Heat Demons.
Old 09-26-2012, 10:52 AM
Bluehighways's Avatar
Bluehighways
Bluehighways is offline
I put these Polly Heaters in my Heritage . . . $39 . . . they put out more heat than you can handle . . . no pun intended. I don't think I've ever had them on "High" because even on "Low" they put out more at 40*F and 65+ MPH than I can use. www.pollyheaters.com/ph400.htm
Old 09-26-2012, 11:14 AM
128auto's Avatar
128auto
128auto is offline
Heated grip is for fall, nothing comes close to heated gloves and gear in the winter.
I have both, heated grip is almost useless in winter, lukewarm I call.
Old 09-26-2012, 11:30 AM
JRK5892's Avatar
JRK5892
JRK5892 is offline
i have a set on my sport touring not my HD, so can not speak about that... but i highly suggest you use a relay and wire them into your ignition to turn on and off... this will prevent you from having dead batteries... if you need any help let me know i wired up mine after push starting the bike 3 or 4 times because i forgot to turn them off!
Old 09-26-2012, 12:04 PM
blueangel73's Avatar
blueangel73
blueangel73 is offline
Never used heated grips, mainly because I read more cons than pros about them. So I went with heated gloves and its night and day when riding in the cold, not more froozen finger tips.
Old 09-26-2012, 12:11 PM
Ridewva's Avatar
Ridewva
Ridewva is offline
Anymore I wouldn't be w/o heated grips. The factory ones have worked well for me, I have them on both the EG and Dyna. But some have posted here with failures, even multiple failures. It'd be interesting to know if HD has done any improvements to remedy this.
I have a couple friends that have installed Koso heated grips on various bikes. They seem like high quality and come with a little LED controller with 5 heat settings. I think the Koso AM107 fits Harleys.
Old 09-26-2012, 12:28 PM
soft 02's Avatar
soft 02
soft 02 is offline
Received 4,571 Likes on 2,889 Posts
I am planing on doing heated inside bar heaters this winter and these look good. Looks like a better set up than Heat Demons.
Old 09-26-2012, 12:31 PM
butterballs's Avatar
butterballs
butterballs is offline
Old 09-26-2012, 12:32 PM
soft 02's Avatar
soft 02
soft 02 is offline
What cons other than the HD units failing...
Quick Reply: Heated grips?
