changing belt
RE: changing belt
You'll have to remove the outer primary, the clutch, primary chain, motor sprocket, etc. in order to remove the inner primary. The rear wheel has to be removed and the swingarm has to be taken loose to enable you to get the new belt over the pulley.
ORIGINAL: rh8234
It isn't too difficult, but you will definately need the service manual because the outer and inner primarys have to come off as well as the rear wheel.
509Rider
06-15-2015 01:49 AM
