Front fork and wheel re-install questions
Hello,
Installing the intiminators I ran into some questions that the manual didn't really cover when putting back together.
The forks. .after you slide them up to the proper height in the trees, you tighten pinch bolts, doesn't say to use loctite, I used blue. Says to do final torque right there on each fork without the wheel in yet. .so. .I saw nothing about 'aligning' the forks to each other. Seems wrong to final torque pinch bolts without the axle in.
So, is there a proper procedure to aligning the forks to each other, or does the axle pretty much take care of that since they have to be lined up for it to slide through both of them?
Next up: those wheel spacers, I know the big one goes on the nut side for a '09. .saw some people have 'v' notches in theirs, mine don't, just some lines on the outside. .i put those lines facing away from the wheel since I think they were like that before. Also saw some people use a drill bit when doing those axle pinch bolts. .don't see that in my '09 service manual. Is it necessary, is there instructions somewhere?
Thanks for your time,
Matt
Matt
