Big Boyz heads
Big Boyz heads
I was looking at them online and they say they can do the heads for $299.00 and get good results. I am running a TW37 Andrews cam and will probably run 9.8:1 compression with a 95 kit. I like to hammer on the throttle a bit but never redline it. I want good street power.
Anyone have experience with the $299.00 headwork? Will I see good results with this set up?
Brett:
Is the '02 (?) FXDXT in your sig pic the bike from which you'll be having the heads ported ...?
I understand the '07-later stock heads are an improvement over the earlier Twin Cam heads and may be just as much improvement for the money ... or you might check with them whether you could send some donor heads from an '07-later motor for them (vice your stock take-off heads) ...
You could probably find some gently used take-off heads on e-bay or craigslist ...
Only thing you'd have to do to make them work is swap out the intake manifold flanges with the later style flanges ...
I've got a pretty similar setup on my 88"-to-95" conversion ...
Good luck with your build ...
R/
'Chop
R/
'Chop
I am interested to hear from someone that has used them to see what their experience was.....
I had my Indy install them-not sure. I will say this;I like the cam as a whole,however I didn't see a dramatic change in performance. I did see a HUGE difference in my Electra when it was done with the same cam. That was with a 95 kit with higher than stock compression.
Sounds like it is at stock timing if it wasn't very noticeable. You can get a key to advance 4° which may be what wakes it up?
