06 or 07 Dyna Low Rider?
Received 4,795 Likes
As mentioned, the '06 bikes had inner primary and stator issues, never heard of any secomd gear or any other tranny problems. That being said, fixing both of those issues can be done fairly inexpensively and if you are mechanically inclined it shouldn't take more than one afternoon. Of the 2 the '07 would be better but I wouldn't pass up a good deal on an '06. It does have the smaller motor but it has the new style cam chains and is geared lower than the 96" motors so acceleration of the line is not bad at all.
+ 1 on the '07, IPB issues, and Stator issues with the '06s were all fixed with '07 parts that included an '07 trans case, inner primary case, and stator/rotor assy. Ask me why I know!
If the owner of the '06 can show you shop records indicating that those parts were replaced, and it's a good deal, go for it. Otherwise, I'd go for the '07.
This will give you some insight; https://www.hdforums.com/forum/dyna-...y-bearing.html
Best wishes....Tim(HT)
+1 on 07. Rode a 2006 (88cu, 6speed, low rider) this summer, vs. my 2008 with 96cu engine, and found a bit different. Keeps up same on highway but different gearing on 88cu makes the revs higher at highway speed. This always resulted in my bike using less fuel than buddies '06 even though I was running the 96cu engine. He said he noticed better jam on mine as well, but it is probably negligible. He also mentioned his transmission nearly went at 24000kms but he replace the plastic bearing as he could hear a noise, otherwise would have been an expensive repair. Not sure if the 07 has that issued with bearing?
