Can't get stock mufflers off.
I got a pair of SE slip-ons. Undid the main bolts for the support bracket and took off bracket from both front and rear. Undid clamp. Everything is free but the stock muffler pipe is hard to budge. Took me an hour to get it to move 1/4 an inch. Tried rubber mallet , twisting, pulling, leverage. Won't come off. It is like someone applied superglue or something.
Anyone else have this happen?
2012 Super Glide Custom
Thanks
Thanks
Yes, this happened to me. Try spraying wd40 where the muffler and header pipe meet. Once it gets between the two parts you should be able to twist the muffler off the header pipe without using undo force or implements of mass destruction. Then thoroughly clean the header pipe before installing the new muffler.
yes, keep working it...spray some lubricant around the area(pb blaster or similar). when you slip on your new mufflers, get some anti-sieze and put it on the inside of the new muffler and on the end of the pipe. should help to go on and keep it from siezing in case some time in the future you want to remove the mufflers. good luck
Thanks
Thanks
