I want to remove my tank emblem without damaging the paint. I see some of you have done it already. Not sure if I should use a heat gun first or just pull them off I don't want to damage the paint.
Heat gun little by little. Work them off show. Clean up the big tape chunks with a plastic scraper and heat gun. Go slow. Then NAPA have edhesive remover or WD40. Take your time. There is no rush.
I did the same as TGWN, but used a little dental floss as a "saw" undearneath the badge after it was heated. I've heard that fishing line works good too.
As said...go slow, very slow. It should take a while to finish the project.
When I took the reflectors off I was using the fishing line and it kept braking. Then I just pulled it off and that worked great on all four reflectors. But I did not want to try that on the tank.
