FXDXT Saddlebag rebuild
Old 03-29-2013, 12:51 AM
t-sportkid01's Avatar
t-sportkid01
t-sportkid01 is offline
1st Gear
Thumbs up fxdxt leatherpro bags
Had my bags for about a week now great bags the only problem i've had was the buttons I've had 3 snap off already and had to have them replaced easy fix but a little frustrating no big deal it is what it is. Oh and already had some one try to steal them and bent the adjuster link so I have to figure out how to replace it. But all around built very strong and they look great. Thanks to leather pros GARY was awsome hella cool dude A+ service
  #502
Old 03-29-2013, 01:27 AM
macnab_sf's Avatar
macnab_sf
macnab_sf is offline
Glad your bags didn't get stolen. Can you shoot a pic of the damage?
I had a button head pop off too. Garry sent me a bag full of new button heads. Thanks Garry!
  #503
Old 03-29-2013, 07:07 AM
07bobber's Avatar
07bobber
07bobber is offline
Same here, 1 button broke off but Garry sent replacement snaps
  #504
Old 03-29-2013, 08:33 AM
Hogpro's Avatar
Hogpro
Hogpro is offline
Former Sponsor
I had the same issue. I have a buddy who has snaps and such so we fixed them with new ones took 5 minutes. Gary offered to fix this for free but I did not want to ship my bags back to him.
  #505
Old 04-02-2013, 08:05 AM
Gibbor's Avatar
Gibbor
Gibbor is offline
Anyone have any idea how these bags hold up to rain? Unlike a good number of you folks that live in areas where it doesn't rain all that much I am occasionally unlucky enough to get caught in the rain every now and then. Just curious if all my swag is gonna get wet if I happen upon some rain? I have a set of Kuryakyn bags that actually have built in rain flys that can be stowed away when not needed. Didn't know if anyone else had though of this?
  #506
Old 04-17-2013, 08:42 PM
parts eeter's Avatar
parts eeter
parts eeter is offline
Originally Posted by parts eeter
Garry,
I am gonna run a Avon 160 size rear tire on my FXDX and want to use the nut plates you show in your video ( the version with BOTH the sleeves threaded) and just want to confirm that the part number for the docking hardware you mentioned also fits the FXDX. I have to do away with any protrusions in the fender area to avoid my tire rubbing so I need those inner fender nut plates like u have.
Did you happen to have the nut plate part numbers individually as I dont need any of the rest of that kit anyway?
Originally Posted by LeatherPro
You might have to drill out the fender and frame holes for it to fit, but the hole spacing is the same. part #60198-06.
garry
OK, well after much time has passed since I received these saddlebags from Gary I finally had some time to install these bags.
I ordered some HD Pt# 60198-06 brackets and waited a week for my dealer to receive them. Once I received them yesterday I decided to get to installing my new bags. I drilled the struts,strut covers, and fender holes to fit the new Pt# 60198-06 fender support brackets.
( I used these brackets so I did not have to have a bolt/nut protruding into the fender well which could possibly interfere with a wider 160 tire on my FXDX)
All was well with the world until I tightened down the new hardware only to discover the 60198-06 fender support brackets would bulge out into the fender well area. I tried everything to try and get them to fit. Heat/dolly/Shrinking/ etc..... They just refused to lay down properly.
So, now I have to figure something out. Well, luckily I have a great hardware shop close by with a girl there that knows her way around the store really well. I came home with 4 stainless 3/8x16 T Nuts, and this trick spanner wrench that had to be slightly modded for me by me. This is what the entire setup looked like.
The craptastic HD fender brackets
No matter what I tried, I couldnt get me to fit. I tried metal shrinking, c clamps, heat, cursing , throwing tools, and drinking beer.
Well, I woke up slightly late today, feeling kinda groggy and tried a new tactic.
Here is the new setup, after I ditched the crapola HD Inner fender brackets Pt# 60198-06.
Bolts are cut to 1.9 inch shank length here.
The required spanner wrench for the new T nuts.
The final result
Now, I could have bolted these on with the hardware that Garry provided, which would have been a 20 minute install. So dont get confused thinking that this is the normal procedure as it IS NOT. I chose to go this route because I wanted to used a wider 160 tire on the FXDX superglide sport. I figured I could use the room. I made this post so that anybody with the 05 or older superglides do not try and use the 60198-06 inner fender brackets, as they DID NOT work for me.
  #507
Old 04-18-2013, 07:56 AM
Danofxdx's Avatar
Danofxdx
Danofxdx is offline
The final result
Thank You I have the stock T-Sport bags and went with a 160 rear, the bolts were installed from the inside with the nuts on the outside so rubbing there has not been an issue, I was checking out a 2012 superglide that a guy I know bought and was thinking about those HD brackets but I like the Nuts you got better was that an Ace hardware that you got those at? I could really clean up the look of my bike with those and some nice bolts
  #508
Old 04-18-2013, 10:31 AM
parts eeter
I got the T Nuts at a Mom and Pops store. I used the HD 60198-06 brackets successfully on my 06 Street Bob to allow use of a 18x5.5 rim and 180 rear tire, but my current steed did not like them at all.
NOTE- The 06 and later fender struts are different than 05 and older Superglides.
Let me know if you cant find the T Nuts locally. The store I bought them from only had 2 T Nuts left and I bought the last wrench they had also, but maybe they will re stock them. If so, I can send you a set with a wrench.
How did you like that FXDXT fender I sent ya??
Which 160 rear tire did you go with on your bike? My roomie has a Avon venom 160 mounted on a laced 16x3 rear rim. It looks really big compared to the OEM 150 Dunlop I have. I havent been able to get an accurate measurement. I need some type of plastic calipers to use for measuring tires.
  #509
Old 04-19-2013, 07:25 AM
Danofxdx's Avatar
Danofxdx
Danofxdx is offline
I will check my local Ace they have a fantastic selection
I just got the fender it really looks good thank you!
I put a Metzler ME880, it’s a little taller and fills the fender out nicely, Metzler does not offer the new 888 in a 160 as far as I can tell They used to have a tool on the website to see what tires would fit and if you could increase above the stock size but I can’t find it now
  #510
Old 04-29-2013, 06:09 PM
Blkbobber's Avatar
Blkbobber
Blkbobber is offline
Im getting ready to order these bags. Any of you guys that have these bags think if I powder coated the docking studs that they would hold up?
Quick Reply: FXDXT Saddlebag rebuild
