Anyone want to rent me their PC-V auto tune?
This is my understanding of this device also. So, even if you could barrow one. Your tune would be usless when you returned the device.
Ok guys..to clarify...
When you add the autotune onto the pc-v, it does not tune the ECM. All it does is take your existing PC-V map, and as you ride it develops trim values. You then go into the PC-V map and accept these changes.
You do this 3 or 4 times until there are pretty much no changes left to be made.
It does not have to stay on the bike, and it does not do anything after it's done it's thing. You can leave it on the bike, sure, but it doesn't actually adjust the AFR in real time for you, it just tells you what to adjust the map to.
This is the use in which I am talking about and why this idea makes sense.
The unit simply observes, trims, and tells you what changes you make. You do this 3 or 4 times then your are done. It does not make real time AFR changes to your map. it simply tells you what to change.
From what I understand, the PCV does not make changes in the ECM, unlike some other kinds of tuners. It stores the map and any changes it makes from the auto tune in its module. So you can spend the time (if you can find someone who will lend it to you) to install it and the O2 sensors, and as soon as you return it to its owner you're back where you started. Needing to buy a tuner.
If I'm wrong someone will tell me soon enough.
could be wrong, butt,
I do believe you're barking up the wrong tree.
To quote Jamie from fuel moto:
"The Auto tune module is universal for these models and can be swapped bike to bike as long as the bike has a PC-V. Tune your bike, tune your buddies bike or tune 100 bikes. "
https://www.hdforums.com/forum/touri...ne-info-2.html
Post #11.
I like this idea a bit (although hate borrowing anything) since I have a PC-V and would love to use someones auto tune to fine tune my map...I was just going to sell my PC-V and buy the powervision as I didn't want to drop another $250 for the auto tune module....so the OP is on to something for sure. I just don't see anyone wanting to rent it out.
Post #11.
Post #11.
Post #11.
$50?
Don't the Wideband O2 sensors needed by Autotune need a different size bung? Seems like this would required mods to your pipes, then plugs when you're done. I think that if I were to go to the trouble of modifying my pipes, I'd prefer to hold on the the Autotune module for future engine changes.
As for Autotune with PV, out of the box the PV unit only does basic tuning with the stock narrowband sensors. Basic tuning covers about 2/3 of your VE tables. PV also accepts input from an Autotune module allowing you to accurately populate your entire VE table.
The PC-V auto tune uses wide band o2 sensors?
The OE ECM "only" uses narrow band o2 sensors.
So, when you remove the PC-V auto tune, you have to replace the o2 sensors. Correct?
