two strange noises comin from bike please help
the first sound is coming from what sounds like the front cylinder head it is like a rattle. it does it while just at idle an while ridin. any idea what these could be?
the second sound is when i shut the bike off, when it is off for about 3 to 5 seconds it will make a burb sound from the "points" cover area. ??????
thanks in advance for any help
Rattling fuel cap! Mine did that. Took me forever to find it. Thought I had an issue in the motor like rocker arms rattling. Next time it makes that noise put your finger on the cap and see if it stops. Had a loose license plate that made a weird vibe and a buddy saw it moving. Also check the shift linkage for a loose joint. Check the rubber bumper for the kick stand too. Good luck. Hope this helps.
You can fix your fuel caps but flipping it over and using a hammer and flat head screw driver or something similar to crimp the chrome cap in a few areas to put a little pressure on the underlying assembly. I read that on here long ago, tried it, and it worked -- not sure who's idea it was...
