Enrichener cable
Enrichener cable
The plastic tensioner nut has broken away from the main assembly. Do I need to buy from the **** to the valve (****, cable, valve assembly) or is there another way to fix it, super glue does not work. ----- Thanks, James lee. Also I need to know which one to by, it has a stock carb. 1999 FXDWG
I just replaced mine on my 97 FXDL I'm betting the process is pretty much the same. The only way to unscew the cable from the carb. is to remove the carb. I did it step by step per the manual which tells you you have to remave the gas tank first. When I finally got to the last step wich was to actually pull the carb off the motor I realized this was untrue. I could have pulled the carb without removing the tank. I'm betting you can do the same.
Collk88
Exhaust System Topics
11-15-2012 08:50 AM
