Pulling Wires through Apes
So I was working on installing my new apes today (14" El Diablos) and everything was going great till it came to pulling the wires through. For a while I was having a very tough time, trying all sorts of things. Finally, I decided to use a piece of shrink tubing (or whatever its called) to cover up the exposed wires and pin connectors and used a piece of safety wire to keep the wire sheath from sliding too much, it actually worked! I thought all my problems were over.........But now, for the life of me I cannot get the wires through on the other side.
Any of you all with apes that have sharp bends have any suggestions? I plan on tackling it again tomorrow, and am keeping my fingers crossed that it will go better than today.
Thanks!
Thanks!
I used weedeater string and some really good tape, taped the ends of the wires so nothing would snag. Left side I did one wire at a time because of some terrible splicing by the first installer. Right side I did them all at one go.
It was still a pain but well worth the effort. (This was with tbars)
What I did to get a leader through was use twine with a nut tied to the end, dropped it in and sucked it out with a vacuum from the bottom. The problem I am having is after I get the leader through, I tie the other end to the wires, it feeds through fine till I get to the bottom 90 degree bend. I did not try using electrical tape (which is probably the same effect of using shrink tube), or greasing the sheath which I will definitley give a try tomorrow, I suspect that is what is bunching up and why I am having so much trouble on that last bend. Thanks guys, and keep the suggestions coming!!!
I use compressed air when I wire tuck. If you don't have a compressor just used canned air. Basically take decent string and blow the compressed air in the bar, it will shoot out the hole. Cover any holes you don't want it to come out of. Then tie your wire to the string, grease them up a little and slide-um through
srhen
04-21-2016 05:15 AM
2008FLHP
11-29-2007 07:54 PM
