Rocker Cover Bolt
Rocker Cover Bolt
I installed black wrinkle upper and lower rocker box housings a while back and everything seemed fine, no leaks. Fast forward a few thousand miles and I noticed a leak near one of the bolts on the front cylinder. I checked the tightness on all the bolts and found one to be completely loose. When I did the job, everything was torqued and I used loctite.
When I removed the bolt, a few threads from the lower rocker housing came with it! Now the bolt will not tighten down, it just spins. Anyone ever have this happen? Is it worth it to try to fix or should HD replace it? (which will probably be a long shot).
I'm in the process of removing them now. I'm definitely going to try to repair it, whether I have to retap or helicoil. Do you think, before I go through all that, that Harley might replace it since it was brand new?
I no longer have the stock boxes and I did the work myself. It will be worth a shot, worst they can say is no.
cvaria
05-20-2013 05:38 PM
