Brake and clutch control lever kit
I am trying to replace my brake and clutch leaver on 06 dyna wide glide.i have a service manual and the instruction sheat.is there anyone who can tell me how to slide the 5/32 peice of cardboard between the brake leaver and the housing?i know it is to protect the brake light switch.is there some kind of trick to this? And on the clutch leaver do i have to put free play on the cable to replace the leaver on the clutch or is it just hold the cable with vicegrips and replace the leaver. I tried looking on the search bar but could not find what i was looking for. Thanks could use your help
https://www.hdforums.com/forum/7378764-post4.html
As for the clutch lever: yes, you will have to give some slack to the cable at the clutch adjuster halfway the left hand down frame tube.
To take off the snap rings you'll need a pair of sharp edged nose pliers:
