Fat Bob fender on a Wide Glide
Have any of you Wide Glide riders put a Fat Bob fender on your bike? What do you need to get the Fat Bob tail light and turn signals working properly?
Thanks
Swap started:
https://www.hdforums.com/forum/membe...-bull-dog.html
Thanks
Swap started:
Biggest issue will be whether the width between the struts will accommodate the fat bob fender. I don't know if the wide glide width is the same, but think it is. Hopefully someone who's done this will chime in to confirm. It's one of the widest out there coming in at about 9 inches and some change. Tail light harness should be plenty long enough and should be plug and play. After putting my street glide fender and tail light set up on my fat bob I didn't have to do anything to the wiring. To give you an idea of the width, my 2011 street glide fender was more narrow than my struts. Do you have service manual? The conduit for the wiring you can get at the dealer. You'll have to de-pin the connectors in order to slide the harness through the new conduit, and the service manual explains how to do that with a special tool, which for me was a large safety pin. That way you don't have to dice and splice wires.
Hey bl_dg
I did the swap. I ended up keeping the wideglide turn signals hooked up as turn and brake lights. I spliced the brake light into the harness before the turn signal brake light modulator box. So now I have three brakelights in the back. All the other things bolt right up. Any questions let me know. Here are a couple of pics of my bike.
Done... almost. Got the fender on, but one issue. The Wide Glide fender support has extra material at the back for the side license plate mount. So now the fender support cover won't fit. What the h*##, H-D... the one model that ALWAYS had the bobtail fender is now the only one that CAN'T take the bobtail fender. Somebody in Marketing should be canned.
Also, mounted the Switchback seat.
Here are some pics:
Here are some pics:
