clutch adjustment now no clutch bite
The cable adjust is just to give you about an 1/8" free play of the lever (IIRC).
Clutch not engaging is the clutch adjustment itself.
The following link is where the other end of the clutch cable attaches on a 6 speed tranny. 07 Street Bob.
Since you did not list your year and bike, you can search for the diagrams on that site.
Thanks all....
Its a 2010 Street Bob.... I was replacing the jam nut because on last adjustment i overtightened it and damaged the thread (its made of softer material for some reason). Engine was cold. Clutch was ok before. I'll look for something coming loose.
OK, I am stumped... the cable is fine.. leaving the lever, at the adjuster and going into the clutch... when i have turned the clutch adjuster all the way away from the jam nut until it is basically off the thread of the cable I get resistance at the lever about 1/2" away from the grip but it doesnt feel like clutch resistance... feels more like solid or hard resistance...
Any more suggestions?? Gonna post in the tech section too....
Received 4,483 Likes
