Motorcycle jack
Old 01-14-2007 | 05:37 AM
Tompop's Avatar
Tompop
Default Motorcycle jack
I have a 2003 Dyna Wideglide. Has anyone used the Pepboys motorcycle jack? And if so, did it do ok for fluid changes and such? [sm=insomnia.gif]
Old 01-14-2007 | 10:49 AM
Roadrider18's Avatar
Roadrider18
Default RE: Motorcycle jack
It's big bucks...but...if you want NO worries when your ride is going up/down and while airborne...take a look at..........
http://www.jsjacks.com/products.htm
Old 01-17-2007 | 07:53 PM
MARCUSBEAR's Avatar
MARCUSBEAR
got a j & s jack for xmas , works great on a 2003 wide glide for motor oil changes , transmission oil change you are better of just removing the plug with a pan on the floor with out the bike on the jack .. the rear bar of the jack is really close to the plug ...
Old 01-17-2007 | 10:48 PM
rgustashaw's Avatar
rgustashaw
If you're referring to the Torin Big Red that Pep Boys sells forget it. Dynas require a jack adapter to be able to use it. I e-mailed Torin...they do not offer any adapters for that jack.
I bought mine 2 years ago when I had a Suzuki Boulevard C90. Worked fine with that bike. I was surprised when it didn't work with my '06 Street Bob. Did some research and found out I needed an adapter. A couple of other jack companies sell them so I might buy one and try it with the Torin.
Old 01-17-2007 | 10:56 PM
Helix's Avatar
Helix
I have it and it works fine for what you want to do. You will need an adapter as others said - It can be had at your local dealer for ...$14 I think. I paid $29 for my jack and $14 for the adapter. Works like a charm.
Old 01-17-2007 | 11:01 PM
glideridemike's Avatar
glideridemike
I just bought a jack adapter for my WG from the HD dealer in town. These pieces fit on the frame to give it a lower spot for the jack to hitso the jack will work on the scooter. Only cost $23 out the door. Same thing was over $30 elsewhere and wasn't specifically for the WG.
Old 01-17-2007 | 11:39 PM
glide05's Avatar
glide05
ORIGINAL: Helix
The plastic adapters from the stealer cost around $23 as glidermike has mentioned. Worth about $5 - but we all know how it is. Needed as the dyna pan is below the frame. Necessary and works fine.
Not sure I'd put a $15K motorcycle on a $29 jack, but that's just me,
Do a search in the forum - not sure the Pep Boys is covered - but if it's $29 - I'd stay away
Old 01-18-2007 | 01:00 AM
Bug_Guy's Avatar
Bug_Guy
Don't need a jack for fluid changes, and don't need "adapters" if you have access to some 1X6 and 2X4 scraps and some common sense.
Old 01-18-2007 | 01:59 AM
Helix's Avatar
Helix
I dont know Glide05 but it was on sale before Christmas down to $29 from$79so I bought It. It hasent had a problem yet and I dont think the price has anything to do with the reliabilty of the jack it seems to work just fine. I could have bought the Sears lift but then again a 15k Bike on a $90 lift - whats the difference.
Paddygfw
07-02-2019 07:47 PM
yepuhuh
"The Florida Crew"
02-17-2012 10:10 AM
tomtek
10-03-2010 06:03 PM
bwhte
02-19-2008 09:44 AM
Manish_Hawg
07-08-2006 12:08 PM
