106 bore kit for 06 dyna
Old 07-03-2012 | 11:55 PM
Knucklehead15's Avatar
Knucklehead15
Default 106 bore kit for 06 dyna
Is there any way to convert S&S part numbers to drag part numbers? Im looking for the 106 big bore kit on S&S's website. But when I look in the drag catalog it only lists 07-12 96" engines. Any one know for sure what drag part # fits the 06 88"?
Old 07-04-2012 | 06:19 AM
OldMike's Avatar
OldMike
I don't think there is a 106 bolt on big bore kit for the 88.
Old 07-04-2012 | 07:31 AM
SC-Longhair's Avatar
SC-Longhair
Isn't the change in displacement achieved by bore only? If so I don't see any reason why the 106 kit wouldn't work on your 88"
Old 07-04-2012 | 07:40 AM
Shredding rubber's Avatar
Shredding rubber
The 106 kit would turn an 88 into a 98 however I don't know if the jugs would be the same.
If you wanna go big bore just buy the appropriate pistons and get your existing jugs bored.
Old 07-04-2012 | 07:42 AM
Good_Apollo's Avatar
Good_Apollo
The S&S 106 kit is for the 96ci engine only. They make a 97ci big bore kit for the 88ci. To go to a 106 on a 88ci you have to bore and stroke it.
Old 07-04-2012 | 07:49 AM
Knucklehead15
Default see link below
http://www.sscycle.com/uploads/featu...ore_kit_lr.pdf
From what I understand the 88 06 dyna is the same engine as the 96" 2007 motors with a smaller bore. What I am looking for is the drag part # for the link above. And any input from someone who used this kit.
Old 07-04-2012 | 08:34 AM
powerlab's Avatar
powerlab
Default 106
U cannot achieve 106 with a 88.Thedifff between the 88 and 106 is stroke...the bore is the same.Also the piston is also diff.With stock stroke u can achieve 98..let me tell ya..a 98 kit in a 88 is a screamer..contact scott at hillside...hes done a ton of them.
Old 07-04-2012 | 10:35 AM
SteveO-ll's Avatar
SteveO-ll
Good_Apollo and Powerlab, nailed it on the head............
Old 07-04-2012 | 11:23 AM
Knucklehead15
Since the 06 dyna is the bastard model. How is the best way to find out what motor components work for it? I want to end up with 110-115 HP. I also don't want to spend thousands ....
Old 07-30-2012 | 08:58 AM
Knucklehead15
I ordered to 106" kit to bump me to 98". I also ordered the primo pro clutch kit and s&s 585 ez gear driven cams. I hope this gets the bike up and going.
Quick Reply: 106 bore kit for 06 dyna
