HD Quick release sissy bar rattles
Just so all know, the optional quick release chrome sissy bar for '12 Wide Glide has no rigid mount available, so you WILL get rattle out of it eventually. Sucks. Just sayin. Tried wrapping mounts with tape but it's only a temporary fix. HD needs to come out with rigid mount brackets IMO.
I had a machinest make some docking point bushings from T-6 alum. bar stock. PITA to shim to correct position but after that, no more rattle.
By the way....I believe the instruction sheet for the QD's says rotate the docking point bushings 90 degrees from initial install when it begins to rattle and to plan on changing them ofter.
Hope this helps.
Best wishes....Tim(HT)
Hope this helps.
