Fuel Capacity Question - Doesn't Add Up
Old 08-27-2012, 07:44 AM
DesertDyna's Avatar
DesertDyna
DesertDyna is offline
Originally Posted by mabbott75
looks like I will have to strap on a gas can and run it until it sputters to find out exactly how much my tank can hold.
Just a thought....it is not good for the fuel pump to run it dry...which is probably why they set those gauges so they read empty when there is still fuel around the pump.
  #42
Old 09-12-2014, 10:11 AM
Rooster3D's Avatar
Rooster3D
Rooster3D is offline
4th Gear
I'm late to the party, but I'm glad I finally found this thread. For years, I've been wondering why my 2010 Wide Glide will only fill up to 3 gallons. I wasn't sure if this was a replacement of the older reserve fuel partition, or some such. Now I see it's just a common "deal with it" thing.
If I trick the pump into topping off my bike, then I only get about 0.5 gallons more. The bike usually spits up a good amount of that extra fuel right through the cap's breather. Anyone else experiencing this?
  #43
Old 09-12-2014, 06:37 PM
rjo3491's Avatar
rjo3491
rjo3491 is offline
Just got my bike. I have the odometer set on clock mode (with trip meter running in the background). Plan on running 4 tanks of fuel through it. That should give me a good measure of MPG and range. After this test, I'll switch off the clock and use the trip meter for my fuel gauge going forward.
  #44
Old 09-12-2014, 07:43 PM
lo-rider's Avatar
lo-rider
lo-rider is offline
Originally Posted by Rooster3D
...If I trick the pump into topping off my bike, then I only get about 0.5 gallons more...
Only the rankest amateur relies on the fuel nozzle to stop fueling a bike.
  #45
Old 09-13-2014, 07:15 AM
Jeff's 1st Harley's Avatar
Jeff's 1st Harley
Jeff's 1st Harley is offline
Originally Posted by jim425
My FXD is about the same. I think I got 4.4 in it once. Usually it's about 3.6-3.7 after the light comes on. I don't push it since it doesn't have a reserve unless I don't have a choice, and there is quite the distance between stations. They are definitely not long range tourers! My previous bike held about 2 gallons more.
X 2 that's pretty similar to mine.
  #46
Old 09-13-2014, 08:31 AM
kainvamp's Avatar
kainvamp
kainvamp is offline
I put in about 4-4.2 gallons everytime I fill up my Fat Bob and it usually says around 15 miles left till empty. Once I got 4.6 in it and it just said low fuel. I think It kind of factors in that .5 gallon as like a reserve, but I wouldn't make a habit of dipping into that last bit. And I do fill it all the way up.
  #47
Old 09-13-2014, 02:12 PM
HotRod9mm's Avatar
HotRod9mm
HotRod9mm is offline
My '13 FXDF is about the same. I put 4.47g in with 179m of mixed riding. So the FB gas gauge is closer
to real life then my '12 RK(180m, light on showing 38-40m to empty = fill up only takes 4g). I bent the RK
float arm 5degrees and the next fill up was about .5g closer(shows 36m to empty and needed 4.5g to fill).
I will check it a couple more times before adjusting the float arm a second time.
Next I will be checking the '11 Super GC and see how it does.
  #48
Old 09-13-2014, 04:09 PM
Lennyone's Avatar
Lennyone
Lennyone is offline
Welcome to the Harley tank gauge, use your speedometer milage
  #49
Old 09-13-2014, 04:43 PM
sonnyq1976's Avatar
sonnyq1976
sonnyq1976 is offline
I have gone 170 miles on a full tank. when i topped off it took about 4.5 gallons. and thats doing about 85 on the highway the whole way. I am sure i could stretch it out a little farther if i rode more conservativly. But 170 is my limit and then its time for gas. I dont go off the gas gauge.
  #50
Old 09-17-2014, 01:20 PM
Rooster3D's Avatar
Rooster3D
4th Gear
:-/ I'm a fuel newb for 5 years.
I'll put my fingers around the tank inlet and cinch up the nozzle boot. This usually brings it out a little to prevent premature shut off. Sometimes I try to get a little more out of it. All seems fine until I crank 'er up and the tank pukes on me.
Quick Reply: Fuel Capacity Question - Doesn't Add Up
