How'd you know your MOTOR MOUNT was BAD?
Old 07-01-2012, 08:30 AM
Austin Dave's Avatar
Austin Dave
Austin Dave is offline
hmmm....maybe that is the cause of the 'clunk' I sometimes experience! '03 has fewer than 10,000mi on it. SM shows 5 'checks' to make. On lift?
Old 07-01-2012, 04:08 PM
Steel Steed's Avatar
Steel Steed
Steel Steed is offline
Got the mount/isolator today (parts department is open on Sundays here). The guy said it's a real pain to replace it.
Well, jacked up the bike, used part of a wooden broom stick to put under the engine, lowered the bike down until the stick supported the engine, then started taking out the four bolts. Two allen head bolts and two 9/16's bolts/nuts. The allen bolts came out easy. The first, 9/16 bolt couldn't be removed because it hit the frame but, after removing the other 9/16, I could wiggle the mount and everything came loose easily.
Then put on the new one.
The whole process MAYBE took 30mins. It was very easy to change.
Took the bike on a short ride around, and it seems this was the problem. I didn't notice any banging when going over bumps like it was before.
I didn't use washers to fill the gap. There was a bit of a gap, but I just put it back on the same way it came off. Hopefully it lasts at least another 18k miles.
edit: added pics
Is it me, or does it look like a different part? I do know I had to adjust the engine height after removing the old to install the new. I thought it was due to the old one being worn out, but after looking at the pics, they appear to be slightly different. Maybe they're the same and the old one is just destroyed. Hard to tell.
Attached Thumbnails How'd you know your MOTOR MOUNT was BAD?-northeast-tarrant-20120701-00151.jpg   How'd you know your MOTOR MOUNT was BAD?-northeast-tarrant-20120701-00154.jpg
Old 07-01-2012, 04:54 PM
J.Sizer's Avatar
J.Sizer
J.Sizer is offline
lots of good information.. glad you're back on the road.
Old 07-01-2012, 05:47 PM
SC-Longhair's Avatar
SC-Longhair
SC-Longhair is offline
Originally Posted by mang0
And you would be overpaying. Ronnie's parts finder shows that oem part is 109.99.
Old 07-02-2012, 01:04 AM
Gommee's Avatar
Gommee
Gommee is offline
Devil's Advocate
I was at the dealer a couple of weeks ago talking to the parts manager. He told me there was an upgraded front mount for the Dyna that was made from a different material. He told me for $160 he would order it for me. You have to realize that once a Harley part crosses the border, it magically doubles in price.
Old 07-02-2012, 04:58 AM
mang0's Avatar
mang0
mang0 is offline
not saying i would buy them (not a big fan of JP), only pointing out that there are options...
Old 07-02-2012, 05:25 AM
rs87277's Avatar
rs87277
rs87277 is offline
good thread
Old 07-02-2012, 06:20 PM
chris h.'s Avatar
chris h.
chris h. is offline
Add me to the sagging mount list. I've got 4000 miles on the clock, purchased one year ago. Guess I'll get it checked under warranty.
Old 07-02-2012, 06:52 PM
SURFOR Chop's Avatar
SURFOR Chop
SURFOR Chop is offline
Hmm ... interesting how much the original sagged ... how worn out and deformed the rubber appears in comparison to the new one ...
Attached Thumbnails How'd you know your MOTOR MOUNT was BAD?-motor-mount.jpg
Old 07-02-2012, 06:54 PM
PoCoBob's Avatar
PoCoBob
PoCoBob is offline
edit: added pics
That's how mine looked when I took them out. You can see in the first picture that the old one has been hitting the engine bracket. Look between the tabs at the top of the mount (front in the picture) you can see that the paint is rubbed off a bit. That is where your vibration was coming from. The mount had sagged enought to let the metal part of the mount come in contact with the metal engine bracket.
Quick Reply: How'd you know your MOTOR MOUNT was BAD?
