Re-position Instrument panel?
Curious if anyone with '03 FXDL has moved their IP from atop the headlight bracket to the handlebar or other position? I just want to move those 4 indicator lamps to a more visible position. I know there are some digital panels available, but the OE round gauges are fine with me. Ideas appreciated. Thanks
I found one at Ebay a few months ago. Here's a link to the Instruction Sheet
There's one more: 59786-06. You'll need 06 model risers for this one though
The part number for mine is 56003-99A I think, but it was discontinued a long time ago. A fellow forum member found this one for me after I had searched for it for a long time. The biggest difference from the one FXD posted above is the bolt pattern, but like he said, newer risers might fix that....I don't know if the riser bolts on the newer models are the same distance apart. I think I had to lengthen my wires a little, also, but since I was doing a complete bar/controls swap with internal wiring, it wasn't too bad.
erbilabuc
03-24-2020 12:35 AM
venturaoutfit
11-03-2015 11:31 PM
